Feature request
It’d be great if LogSeq could be set to, optionally, add uploads to a subfolder with the year. Perhaps under options one could set the default upload folder? Something like:
/media/2022/
/media/2021/
Why would this be helpful?
Once you get a few gigabytes of images and pdfs in one folder, MacOs starts to have trouble quickly opening this folder, in my experience. This makes it difficult to actually sort through all your files. Breaking things up by year is an easy solution. I guess if you’re adding an even larger volume of uploads then breaking it up into year/month may also be good, something like what Wordpress’s media library allows for.
