Hey everybody !
I’m experiencing a persistent issue with Logseq across multiple versions (10.2, 10.3, and 10.4). The application throws an error related to the UI, specifically: "Error caught by UI! Error: No protocol method IInterpolate.interpolate-positional defined for type null."
This error significantly impacts usability, as I’m unable to use Logseq after a few minutes post-launch.
Steps Already Taken:
- Rebuilt the search index.
- Relaunched the application.
- Cleared the application cache.
- Uninstalled and reinstalled Logseq.
- Tested across different versions (10.2, 10.3, 10.4).
Observations:
- The issue is consistent across versions 10.4, 10.3, and 10.2.
- In version 10.2, the bug takes a slightly longer time to manifest, but it eventually does, leading to the same unusable state.
- The error appears to be UI-related and occurs after a few minutes of usage, rendering the application inoperable.
I’m seeking guidance or a potential fix for this issue. Any insights, workarounds, or updates that could resolve this problem would be greatly appreciated.
If further information or logs are required, I am willing to provide them.
Thank you for your attention
