Calendar-plugin
I have activated the logseq-calendar-plugin because I was looking for a way to create a journal page for the past.
But I already do not get along with the plugin. Is there a detailed tutorial somewhere?
Thanks
Actually, there is not much to document; click the calendar icon and select the date you want to open/add the journal-page for.
What aspects are you having trouble with?
Things you can check:
  • The plugin is actually called “Journals calendar” or “Logseq journals calendar”
  • You may need to enable the icon for “open-calendar” under the puzzele-piece icon
  • The first day of week seeting is inside the plugin settings, the graph-wide setting is not used
EDIT: It seems, you have installed the “Calendars plugin”: That on is just for copying Outlook entries to today’s journal, try the Journals Calendar.
