can I use pdf annotating for some pdfs outside of graph with pasting their links?
I just did some testing, and apparently you can.
Place a link in your notes
![Title of the Document](/path/to/the/pdf_file.pdf)
and it should become [[📚Title of the Document]]
when you exit edit mode.
If you click the link, it will open the file on the left (as usual). Highlighting, referencing, etc. should work normally too.
Hmm
My testing was done on a Mac.
If you’re on Windows, you could try starting the path with file:///d:
… and then replacing all the \
with /
Can’t be sure, though.
this is right for windows. thank you very much sir.
