In Logseq’s whiteboard feature, is it possible to click on a card and then have a full view of the card appear on the right side for editing, similar to how it works in Heptabase?
logseq的白板使用中,可以像heptabase那样,点击卡片,然后在右侧就出现卡片全览以便进行卡片的编辑工作么?
If your “card” is a block, then yes, you should be able to hold SHIFT + click on the block to open it in the right sidebar.
Just make sure that the block is expanded.
Thank you very much for your reply, but it still seems a bit cumbersome to operate. It’s not as straightforward as Heptabase where you can simply click on a card and edit directly in the pop-up box on the right. I’ll pay attention later to see if there’s a plugin that can achieve this.
Okay, thank you, and wish you a good mood.
非常感谢您的回复,但操作起来还是比较麻烦,不像heptabase那样可以直接点击卡片就在弹出的右侧框里做编辑工作,到时再关注下有没有插件可以实现吧
好的,谢谢,祝您好心情
