Every time I start a bullet point, Logseq converts my initial letter to a Capital forcing me to go back and re-enter it. How can I stop it from do this? Thank you for any assistance.
Welcome. This has never happened to me. And I don’t see any reason for an outliner like Logseq to have such a behavior. Please check if it is caused by something else in your system.
You are right. I generally use Logseq on a Samsung Galaxy TAB S8+ which is where my issue is happening. I also have it installed on a Pixel 6a phone and a desktop computer running Void Linux. The issue isn’t present on either of these devices. Time for me to do some digging. Thank you so much for your reply. Have a wonderful day
I was able to solve the issue on my Samsung Galaxy TAB S8+.
I went into setting and searched for capital. Look for Auto Capitalize. Choose it and change the slider. Problem solved. I hope this helps.
