When I try to interact with toggles in the editor section of the settings, nothing happens. When I change the preferred workflow option it doesn’t save either, as in the option reverts back to the previous setting after a restart.
Short update: it seems like this only happens with one specific graph that I have, when I change to a different graph all the options work fine.
Did that get solved?
same Problem here. It works allright if I start a new graph. The settings seem to be graph specific and do change back wen I switch to my graph. no reaction on Workflow (Todo/done) and show / unshow parentheses
