Capture 10x faster on Logseq using SupaSend app
Hey everyone,
I’ve built a lil app that focuses on capturing your ideas, notes, thoughts quickly on Logseq via SupaSend(Even though it is easy to capture on Logseq, I went into the rabbit hole of what if there is even a faster way to do it).
SupaSend iOS is a complementary app that amplifies the way how you capture on Logseq.
You can
  • create a note with or without a file, audio, photo and scanned document
  • append text in existing note with or without a file, audio, photo and scanned document
You can download the app from here ‎Note to self - SupaSend on the App Store
We’re continuously improving it. Hope you all get a chance to try it out.
Thank you
Pradeep
Any chance of enjoying this as an Android OS app?
I currently use Todoist as Quick capture gate from my Android to Logseq.
Incredible app. I had recently sketched out an idea to build something similar. Nicely executed.
+1 for Android
Logseq is privacy focused, as is Obsidian.
Is this capture app privacy focused?
It would be awesome if it could also parse URLs - especially X threads of tweets - and add it optionally as content to the entry. Same for youtube video transcripts etc. I’m playing around with lazy.so but I’m not happy with the functionality. I would love a mix between logseq and lazy.
And a good question regarding privacy!
Why do I need an account?
Uninstalled.
