Hi,
I tried to use a custom theme per graph as suggested here like this:
@import url('https://logseq.catppuccin.com/ctp-frappe.css');
:root {
--ctp-primary-background-color: blue;
The background color doesn’t change to blue
Hi,
:root {
Hi @alexzeitler
I don’t think you can override the theme like that since the actual CSS variable used by Logseq is: --ls-primary-background-color. In my experience you need to know some CSS and treat Logseq as a website when applying your own styles. Just open Dev Tools (on Mac: View ->Toggle Developer Tools) and inspect the elements you want to style.
If you look into the CSS file you imported you will, eventually, see the the row:
--ls-primary-background-color: var(--ctp-primary-background-color);
Which means that --ctp-primary-background-color is declared and then used. When you then declare/override the --ctp-* variable it will not be applied to any elements.
tl;dr
to change the sidebar background you can either:
--left-sidebar-bg-color to the choice of your color e.g. --left-sidebar-bg-color: green !important;.left-sidebar-inner@gh_hy44 thanks, overriding the .left-sidebar-inner class in custom.css did work like this:
.left-sidebar-inner {
background: green !important;
Updating the variable like this didn’t work (in custom.css):
