Change colors of single words or part of sentences
Hi to everyone,
I am trying to define a macro in order to change some words’ color. I’ve followed what also discussed in this post of the community, the problem I am encountering is that by defining such macro is that the colored text inserts a “newline” just before and after, like in the pictures added below.
Is there a way to color a part of the sentence, without having it on a new line?
20230927_12h44m54s_grim
(already tried with something like:
:light-yellow "[:span {:style \"color: #d9d898; display: inline\"} $1]"
or:
:light-yellow "[:span {:style \"color: #d9d898; display: inline !important; white-space: nowrap;\"} $1]"
but does not work
Thanks in advance for the help!
Try putting the following rule in file custom.css :
div.macro[data-macro-name='light-yellow'] ,
div.macro[data-macro-name='light-yellow'] div.hiccup_html
  display: inline;
Thanks a lot, this solved the problem. One last question: do you have a hint on how to treat bold and italic inside that colored text? Do I have to re-define them somehow for each color?
Let me explain: by typing: {{light-yellow "text **here**"}}, I am not obtaining the word here in bold, but it prints also the star symbols: what I get as output is “text **here**” instead of “text here”"
For further formatting should use either:
  • html
  • hiccup, like you already did
    • e.g. [:b here]
    • or better:
      • apply some class, e.g. {:class "classname"}
      • define its style in custom.css
Thanks a lot for the suggestion!
This is great information! Thank you both. This post shows how people in community forums/board should behave: 1) a clear, concise question; 2) a very polite response with another code block to make it easier for the OP; 3) additional information; 4) gratitude. It’s so refreshing to see this. I wish all posts were like this! :blush:
