I have version 0.8.12, when I click on check for updates it does nothing(current version is .8.14).
How do I update?
What OS are you using?
Linux Pop_Os 22.04.
I’m using HP Z1 Workstation 2012, which is very old, don’t know if that may be the reason.
No, being old shouldn’t be a factor here. How did you install logseq? Via the appimage?
I installed it via the appimage.
Don’t worry now it works, I just updated everything and it updated Logseq too.
