Is there any way to create checkboxes outside the TODO functionality? Have searched here and tried standard markdown with no success.
The syntax is
first line of a block (then do a shift-enter)
* [ ] empty check box (note that this needs to be in the same block as the previous line)
+ [x] filled check box (yes you can use either + or *)
The catch is “checkboxes outside the TODO functionality” cannot be in the first line of a block.
Thanks - I had notes on this but was missing the importance of the *
@WQing Do you know if there’s a quicker way to do this?
Right now for me it’s
- shift + enter
- Shift + 8 (to add the star)
- Spacebar
- Square bracket
- Spacebar
- Right arrow key (to move out of the bracket)
6 steps to create a checkbox just seems like a lot of steps, I wonder if I’m missing something. I tried creating a text expansion snippet with raycast, or just copy pasting * but that always create a new line block.
Welcome. Consider using Make custom macros that replace themselves with their value on first run. It is not quicker out of the box, but it can be made so, e.g. compare:
- this:
\n* [ ] first\n* [ ] second\n* [ ] third\nrepresentsshift + enter
- with this:
{{c3 first,second,third}}- Depending on your scenario, you may get away with just a single comma for every extra entry.
