Hi all,
I have seen footnote in this page on the documentation
But for some reason I can’t click the footnote to jump to the footnote location. Is there a way to have the jump functionality on the footnote?
Thanks!
Hi all,
Thanks!
It’s working for me now, could you give it a try again? Discord
Thanks, this example works for me!
But I think there was some bug if we have a hyperlink in the beginning of the footnote, for example
example [^1]
[^1]: [Learn Datalog Today](http://www.learndatalogtoday.org/)
on my end it somehow doesn’t render the clickable footnote.
yes I have that bug too. I filed a bug report here Footnote rendered incorrectly if the footnote definition is a hyperlink · Issue #3622 · logseq/logseq · GitHub
No problem on macOS.
