Cloze not running
Hello, I just made Flashcards run smoothly, however learning Cloze and no results on Logseq 0.10.9.
In a Logseq page:
Attempt 1: I enter “The quick brown {{cloze1 fox}} jumps over the lazy {{cloze2 dog}}”. however the brackets and text are higlighted yellow.
Attempt 2: I enter “The quick brown {{c1 fox}} jumps over the lazy {{c2 dog}}”. however the brackets and text are higlighted yellow.
Attempt 3: I enter “The quick brown {{/ then select Cloze, then type fox}} jumps over the lazy {{/ then select Cloze, then type dog}}” and then select Enter. This outputs “The quick brown […]. jumps over the lazy […]”.
I think Attempt 3 is correct, although I’m curious why typing in curly brackets is not accepted and I need to type the slash?
I then run Flashcards and the page named Flashcards spaced repetition, where said page is embedded, however I see no results?
