Currently there is not hotkey combo for adding highlights, would be great to assign Cmd/Ctrl+H for adding highlights to selected text.
Also it would nice to be able to type in “^^” for selected text to add highlights.
Currently if you selected text and type in “^^”, the text would be replaced by “^^” instead of being highlighted
Isn’t there already …
Ctrl+Shift+H
PS: Wouldn’t Ctrl+H bring up one’s browsing history?
Its currently working, but only with default markdown highlight (without color highlight and no way highlight code block like in Notion)
Found this topic because I wanted the exact same thing. Typing ‘==‘ at the beginning and end of sections is tiresome.
Aryan
5
Try control/command shift h
