I’ve made a bit of use of the :block-hidden-properties configuration, but I find that it’s not always the right approach. I often want to hide properties (like tags and categories) that are unsightly, but also be able to conveniently edit them.
I’ve tried using the below, but sometimes the property is displaced and popped out above the hidden block and when that doesn’t happen, the property doesn’t seem to be applied.
#+BEGIN_HIDDEN
myproperty: myValue
#+END_HIDDEN
I think it would be convenient to be able to collapse properties almost like a child block or to be able to syntactically designate them as hidden when in view mode, but editable when in edit mode.
