I want to simply collapse the current block to its parent.
This seems only possible if I first select the parent block with CTRL-a, and then repeat until I have reached the outer-level I want to collapse to. Only when can I use CTRL-<up arrow> to collapse the block.
This is slow and frustrating. The UI lags. It highlights each block level with each press of CTRL-a. The intervening step is a nuisance.
It seems intuitive to just have a single shortcut to collapse the current parent. Better still to be able to do something like 3cb or cb3. Or simply allow CTRL-<up arrow> to collapse the current parent block. Then perhaps have it work with a number operator as well.
