I wondered if others also think it would be nice to collapse quotes or source or other environments? They often take a lot of space, but “hiding” them as sub-blocks makes them a bit too hidden. Maybe collapsed form could show the first line and then ellipses?
You can already do this in normal Logseq blocks. Add additional lines in the same block using shift-enter
. Those additional lines can be be hidden when you collapse the block, leaving only the first line showing.
- First line of normal Logseq block.
Second line of the same Logseq block.
Third line. When you collapse the block, only the first line will show.
