Hi all,
After using “awesome ui” and removed from logseq, some pages shows “colored blocks” of text that I’m not able to remove.
Changing theme did not solve it.
Please advice.
Jose.
Hi all,
Please advice.
Jose.
I think a rightclick on the bullet and then hit the most right icon “-” on the coloured bar will fix it.
Hi,
Sorry but I can’t fix it, “embebed” blocks (I’m not sure) shows this coloured flavour. Current theme “logseq-bonofix” doesn’t have this configuration.
Looks like you have the panel-coloring plugin enabled? Try disabling that.
Yes!, sorry for the misunderstanding, I didn’t see it.
