Command + mouse click to select multiple blocks
Currently Logseq can only do “shift + up/down” to select multiple blocks, yet this can apply only to blocks in an incessant roll. Workflowy has a feature that one can press command (OSX) and mouse click blocks one by one to multiple select them (even they are not in an incessant roll). One can also de-select individual blocks from “shift-selected” blocks. This feature really helps when one wants to select from a whole list those blocks sharing certain same ideas (yet not placed in a roll) and copy/cut/copy as refs/move together to further integrate them. We need this feature to more accurately handle selected blocks.
This makes a lot of sense as most programs follow the same mantra of allowing multiple non adjacent elects to be chosen by holding down ctrl|cmd
merged feature request - @bader
I sometimes want to highlight a large amount of text that spans multiple blocks. My normal method for this is to click at the beginning of what I want to select, scroll to the end, and then shift+click to select the range of text.
This currently works inside a single block, but if my text spans multiple blocks, instead of selecting the text, it just moves the cursor to the front of the block that I shift+clicked in. I notice that for a few milliseconds the text in the starting block is highlighted just before the cursor moves.
I’m not sure if this is a bug or a feature request, so I figured I’d start with feature request.
If I’m not in editing mode (i.e. there’s no cursor in any block), I can cmd-click on any block to select it.
Unfortunately, this doesn’t work if I’m in editing mode. In that case, I have to hit ESC first before I can then cmd-click on some block.
But it’s very hard to know whether a block is in editing mode (i.e., whether a cursor is inside a block).
(Side note, the default theme for logseq should highlight the a block that’s being edited, e.g. some yellowish background for the whole block, but I guess I’ll file that as a separate request).
In other words, it’s hard to know whether I need to hit ESC before I can cmd-click.
Request: cmd-click should work the same way regardless of whether a block is being edited; i.e. editing mode should be exited if need be.
Note that shift-click does work as expected already: it works regardless of editing mode. So cmd-click should work the same way.
Btw, normally cmd-click adds to the current selection of block; i.e., if you already have a block selected. But in this case, even though the cursor is inside a block, it should not be considered selected. So that when cmd-click is hit on another block, there should only be 1 selected block, not 2.
I think this request to allow selecting multiple blocks in visual mode should not have been merged— it is a distinct request, to be able to select arbitrary text spanning consecutive blocks, as opposed to a request to select multiple entire non-consecutive blocks.
For instance i have this long introductory paragraph and finally i say the important part and introduce a nested list:
  • A thing.
  • Another thing.
I should be able to select the bold portions (starting with “the important part”) without it switching to “select the entire block” mode. (At least, the select entire block is what happens now; it seems it was even worse when the request was originally filed.)
This feature request was implemented at some point:
ctrl+click selects blocks, non-contiguous if desired, and ctrl+click on a selected block unselects it.
