Comment Feature
Hi,
Does anyone know to use the comment feature?
I tried but nothing shows up and wonder how to use it properly.
#+BEGIN_COMMENT
#+END_COMMENT
@vincentteoh that’s by design, anything you put in comment will not be visible
<Comment - Inlines a comment in a block. Comment is only visible when the block is being edited.
Thank you for your clarification about this.
