I don’t like the extra space at the top and bottom of code blocks, so I tweaked it:
The language marker is hidden on hover so it’s not a problem.
.CodeMirror-scroll {
padding-bottom: 48px;
padding-top: 0;
overflow-y: hidden !important;
.CodeMirror-hscrollbar::-webkit-scrollbar {height: 4px;}
.CodeMirror-vscrollbar::-webkit-scrollbar {display: none;}
/* language marker */
.extensions__code-lang {
background: var(--ls-secondary-background-color); /* change this color if it doesn't fit your theme */
opacity: 100%;
margin-top: 2px; /* change this number if it doesn't fit your theme */
z-index: 99;
.extensions__code-lang:hover {
opacity: 0;
