DISCLAIMER: The following discussion, although interesting, it gets technical.
- You don’t need to understand any of the following stuff in order to use Synthesis.
Short version
Compared to other programming languages, Synthesis has:
- a lot of similarities
- Most programming languages are similar to each-other, because they target the same computing architecture.
- a lot of differences
- Natural languages are for common humans, while programming languages are for experts.
- The programming language that comes closer to Synthesis is pseudocode.
- not well-defined, but Synthesis can resemble most of its variations
Long version
There are endless ways to classify a programming language.
- This is highly problematic:
- as languages tend to:
- fit into multiple classes
- yet only partially to each one of them
- because languages are designed:
- to serve specific needs
- not to satisfy theoretical classifications
- Designing a language is all about making design choices.
- plenty of trade-offs to consider
- Therefore, rather than trying to fit a language into classes
- e.g. could say that Synthesis is a general-purpose multi-paradigm very-high-level reflective etc. meta-language:
- Such a statement:
- carries very little actual information
- is potentially misleading
- Such a statement:
- it is more meaningful to list some of its design choices (especially the implemented ones):
- simplicity
- easier to both learn and use than both:
- most programming languages
- most natural languages
- but also in implementation
- easy to maintain and extend
- some examples are marked lower for adhering to the KISS principle
- truly high-level (or human-first)
- targets common humans
- not machines, but also not experts
- can be adapted for non-English speakers
- though it doesn’t facilitate advanced grammars
- Could use an LLM to translate from advanced grammar to simple one.
- extreme modularity and scalability
- Synthesis uses only two units (KISS principle):
- definitions
- similar to Logseq’s blocks
- essentially expressions that provide some functionality
- Synthesis encourages (but doesn’t enforce) next-level DRY:
- breaking composite expressions into separate reusable blocks
- grouping relevant definitions under the same ancestor-blocks
- modules
- similar to Logseq’s pages
- essentially named block-spaces that provide a local static context
- they delegate to each-other, e.g.:
- Consider these steps:
- page G/A in my graph G asks something from page G/B in the same graph
- page G/B defines an API to page F/B, which is in my friend’s graph F
- page F/B delegates to page F/A in my friend’s graph
- Effectively my page G/A gets its answer from page F/A of my friend.
- It doesn’t need to worry where the answer came from. When pure, can even be:
- downloaded from someone else who hosts my friend’s page
- ensuring the version and safety of the file
- executed locally, for local logging and debugging
- without messing the local graph and model
- All these are both defined and communicated in the same natural language.
- This approach allows for endless scaling, avoiding special constructs and protocols.
- no classes
- generally inferior to a type-system with multiple dispatch (see lower)
- definitions
- context-orientation
- a mostly unexploited paradigm that fits the human mind like no other
- among other things, it enables self-adaptation
- static context
- narrow: block-based
- takes full advantage of Logseq’s outliner
- broad: page-based (thus also namespace-based)
- allows the creation of domain-specific subsets of the language
- dynamic context
- narrow: type-based
- intuitive left-to-right multiple dispatch
- broad: caller-based
- explicit state, yet without side-effects
- balanced type-system
- primitive types
- the four basic JSON types with their literal expressions (KISS principle)
- namely: floating point number, free text, ordered list, dictionary of key-value pairs
- not booleans nor null: These can be words (see right below)
- word-type: for plain real words (or word-first)
- some words are predefined (e.g.
yes,no,voidetc.)- These are words, not keywords.
- they don’t correspond to memory addresses
- memory is addressed naturally
- e.g. with pronouns: it/them, that/those, this/these
- they act as both words and values
- but they don’t have fixed values
- their meaning is context-specific
- in the same context, identical words have the same value
- space character
- Logseq’s outliner takes care of the indentation.
- Consecutive spaces are treated as one.
- like in most environments
- Lack of space is not always ignored:
- it often merges the words into one
a - bis a subtracting expression- can be overriden, because
-is a word, not an operator
a-bis a composite word- composite words can be treated both as one and as multiple words
- This is by design.
- it rarely has a special meaning
a=bis a simple worda = bis a comparing expression- can be overriden, because
=is a word, not an operator
a= bis an assignment statement- shortened version of
let a b - cannot be overriden, because here
=is a suffix
- custom abstract types
- simple wrappers of other types (KISS principle)
- Nothing is intrinsically abstract, it simply can be viewed in abstract ways.
- no inheritance, no troubles: fully-possible for the future, though few chances
- platform-specific system-types
- Synthesis is currently based (on Logseq, on Electron) on Javascript.
- This is for purely practical reasons.
- This carries over some of Javascript’s own unfortunate choices.
- primitive types
- simplicity
Conclusion
- Design choices like the above should make obvious that Synthesis has the following:
- non-priorities: familiarity to programmers, performance, completeness
- such things can get improved, but without competing to specialized software
- if you need them, prefer using the right tools
- Synthesis can call some of them
- priorities: familiarity to common humans, flexibility, innovation
- no surprise that Logseq is a fitting platform
- Synthesis is purposely different enough.
- Logseq already supports clojure, datalog, javascript, python, r, and even some tiny DSLs
- no need for another language similar to them
- although it wouldn’t harm
- especially since Synthesis can call them (to various degrees)
- Is that relevant with AI around?
- Short answer: AI makes Synthesis even more relevant.
- Long answer: [Comparison of Synthesis to modern AI] (topic under construction)
