How can I copy a block reference on mobile?
On desktop I would right click a block. Is there an equivalent for mobile?
Thanks!
Hi, have you find it?
You can long press on the bullet to trigger the block menu.
Hi, it doesnt work for me on iPadOS.
You can swipe across a block from right to left to open a context menu at the bottom.
Works on iPadOS and Android phone. (My two devices anyway)
