We use Azure DevOps for our stories, work requests, and so forth, and I’d like to reference these in Logseq using the numbers. So if I have User Story 12345 I hoped I could somehow create a tag or something in Logseq so I could create something like ADO12345 and it would create a link dynamically to the ADO page which is https://#####/_workitems/edit/12345/ . Is this possible? Thanks.
Welcome. You probably want a macro:
- Could define it like this:
:ado "<a href='https://#####/_workitems/edit/$1'>ADO$1</a>" - Then use it like this:
{{ado 12345}}
Thanks – I’m still learning about logseq and hadn’t heard of macros … this worked great, and I’ve built a few more that are helpful. Thanks!
