I have a page titled ‘Cats’ in Logseq, and I want all the blocks within that page to automatically have the tag ‘#animals’. Is it possible to achieve this without manually indenting each note under a ‘#animals’ parent tag? I’m looking for a more robust and organized approach since I will be adding many indentations, and I don’t want it to become messy.
I would suggest to reconsider your overall approach.
- Indentation in Logseq is not particularly messy:
- Can collapse branches.
- Click the arrow on the left.
- Can focus the view on single branch.
- Click the bullet on the left.
- Some nodes (like a cat) should probably be separate pages.
- Indenting multiple blocks is possible, after selecting them:
Ctrl+Aa few times to select all. -
Tabto indent.
- I’m not aware of a way in Logseq to apply a tag to multiple blocks at once.
- This sounds like a job for a plugin.
- It is possible at the markup level in external editor with regular expressions.
- I doubt that this is a good idea.
- Animals is a superset of cats, therefore it should be a property of the
Catspage as a whole.- Properties of a page can be set on its first block.
- Properties can apply to individual blocks as well, and they support plenty of values.
- I would use singular (
animalandcat) instead of plural (animalsandcats).
