Hi!
Does anyone know what CSS code I can use on the .css file to change the background color, editor and panels? Thank you.
Welcome. Test this:
#root>div {
--ls-primary-background-color: #55aa55;
--ls-secondary-background-color: #5555aa;
Then pick some practical values.
Is there some comprehensive list of all the controls that one can use to style the interface?
UPDATE: Look in css files here.
For --ls variables, look at the first 200 lines inside file common.css, either on your installation or here.
Besides what was already stated about CSS variables, here’s how to drill down on what rules impact which part of the interface. If you know your way around HTML + CSS, you can identify which selector(s) to override in the following way:
- Make sure you have developer mode enabled via
... > Settings > Advanced > Developer mode - Go to the Logseq page of your choice
- Hit
CTRL + SHIFT + iorALT > View > Toggle Developer Toolsto open the Dev/Inspector Tool (thread)
From there, you can mess around with the existing rules using the Element selector and Styles panel:
And copy-paste your new rule or declaration into custom.css:
Thank you a lot @candide!
