Win10, Chrome, logseq webapp, German keyboard:
When I hit ctrl+shift+p
the browsers print dialogue opens and the logseq command palette is shown. The former should be prevented in my opinion.
I think you can adjust your LogSeq shortcut to be something that doesn’t interfere with the browser, in settings.
Yes, you can change the shortcut on the LogSeq side. The thing is, I use ctrl+shift+p in Visual Studio Code quite a lot, so I think it makes perfectly sense to have the same shortcut in Logseq, too. It’s only that I can’t modify Chromes shortcuts natively. That’s why I’m asking for Logseq to prevent Chromes default reaction here.
