What triggered your data loss? Multi-device sync or something else?
Today was a frustrating day with Logseq. I have had multiple instances of data disappearing when syncing between mac and windows. Smart merge enabled. Luckily, I could restore on one device, but with the amount of changes I make I am sure I am losing some edits that are forever lost.
Exact same thing happened to me. I was on a 4 hour flight. Did a ton of work on Logseq. As soon as I connected to wifi, my laptop synced (using Logseqās sync) and then all my work was gone. Iāve been trying to look for third party sync to use and thereby dump logseq. Even icloud sync seemed to be more stable than this.
@lsdjr72 @arudiuk
Sorry to hear about that, have you guys tried page history?
Also, please make sure smart merge is enabled on all your devices.
Smart merge is enabled on all devices. So far I have managed to recover everything, but I make changes across multiple pages and it takes quite a bit of time to go to each page and recover. I even find myself having to recover/correct a page multiple times.
I also worry that if I donāt catch a sync mistake, I will forget I ever added anything and lose that information.
Lost a dayās worth of work today. The bak folder was no help either. Have been using Logseq for a bit over a month and have really enjoyed it. Not using any sync features, just have the files in the Document folder on my Mac (and only using Logseq on this one computer). Not sure if I will keep using Logseq after this, feels really scary.
I know this should not be necessary for an app you want to rely on, but I would urge everyone suffering data loss issues to set up a git repository. Install git, go to your Logseq graph folder in the terminal and type git init. Then turn on auto commit in settings->Version control->Enable Git auto commit. Set the time in seconds (I have mine set to 60 just to be safe).
This will pretty much ensure that if you ever see data missing, you can quickly and easily recover it. You can even view page history directly within Logseq, although itās not the best experience. Something like VS Code will highlight changes between versions of the note, which is helpful.
I guess for the people who have Logseq sync wiping out their data, this could also affect the git folder, which would not be good. But if youāre just working on one machine, this is a good solution.
I just recently experienced this. I think making it much more obvious when youāve been logged out would be a UX improvement. Its really not that visually obvious currently, and there is no popup to notify you to login again.
Experienced major data loss today because of this Sync issue. The order of events is as follows:
- Logseq Sync is enabled
- Logseq keeps prompting me there is a conflict between cloud version and the local version as I type.
- I disable Sync and keep writing
- Before I stop for the day, I re-enable Sync
- The next thing I see is my dayās work is gone. The cloud version has overwritten the local version.
- I manage to recover some of it by restoring the last version from page history.
Lesson here is either never use Sync or if you do use it, never to disable it, I guess.
Another day, another data loss. This time page history didnāt save me, either. I lost an hour of my notes. Hoping the team finds a solution for this issue quickly. Losing data on a daily basis undermines the credibility of the entire project in my mind. I still use it because I have multiple backups, and time machine, but Iām still losing data on a daily basis.
So⦠this critical issue not being resolved, and there being no commentary here about it ā this makes me feel like something significant has been abandoned. Is there any consensus as to the state of the Logse
The team is working on the DB version which is the only way to improve the syncing and to solve the issues like yours
not to be picky but it isnāt the only way to improve sync (there are mountains of file based sync implementations that do this just fine without catastrophic lossā¦) and a db backed system doesnāt actually solve these issues inherently. it sounds like it is a good way to go and the way theyāve choosen to do it. a db backed sync process is going to have its own liabilities and issues that are not dissimilar from a text/block sync pattern and is actually going to have the solve sync issues between files on disk and the db. a db backend will likely improve performance for large datasets and syncronization ā not improve accurace or reduce failures.
additionally this bug is not looking like an actual sync issue. sync works great except when the system logs you out without notification. this could certainly be handled better than a silent failure.
sadly (very sadly) i think weāve found the end of my road with logsync. i will dearly miss the superior implementation of a great number of things but if this is the way the dev team are handling this issue iāve run enough software projects to have an intuition as to where this is going. what a shame. Roam is run by people whose politics I canāt personally abide and the other tool that works as I like is logseq which has caused the loss of more than 50 hours of my work (even with time machine and scripted backups⦠my losses were work that logseq never wrote to disk!)
lack of transparency, failure to pull or repair a horrible bug, pushing resolution of an issue to an eventual/planned retooling or rewrite⦠i get it and iāve been there, but cāmon.
Happened here again too, happened twice. It really is foundational for this to work, especially when Iām paying for it!
Iām not even asking for smart syncing, I just want it to fail safe and not delete, rather than just silently delete many chunks. If youāre diffing between files, why canāt they go chunk by chunk and choose whichever side adds, never removing data. Then flag it and ask if you want it start removing things. Itās so much easier to look and say āoh yeah, I wanted to remove that chunk but it got restored, let me press deleteā than recreate text which took hours to generate and is days later
And for the times when itās a 50/50 diff, a word replaced here, Iād still rather a more interactive method than just deciding. But itās so much more a minority than itās not worth waiting to fix the broader issue
So incredibly frustrating to lose work and see new changelogs which address anything but that. Iāve seen so many forum posts about this, if it happens again and itās not in my backups, Iām gone
I really like it too
You are not, please read this comment:
Same, I have experienced multiple sync failures and am concerned about data integrity. Often times, I am working locally (e.g. when on a plane), and when I am back online, the cloud version overrides my local copy ā destroying all of the work I did offline.
This becomes even more of a problem when I add/edit multiple pages, and when Iām back online, and it syncs, I have no idea which pages got overridden/reverted, and which ones havenāt. So Iām completely in the dark.
And just today, another issue cropped up where Iām getting an error connecting to the AWS server. When I click on the URL in the error message box, it says something about being disabled.
Data integrity is extremely important and I hope the Logseq dev team prioritize making sure the sync feature is rock solid so that data loss is no longer an issue.
Chiming in because Iāve also experienced a huge data loss. Nothing written in the past 2 weeks has been saved ā not even in Syncās history or bak. I donāt even know what to do⦠![]()
I wanted to report that I had significant data loss for unknown reasons. Many of my journal entries were completely wiped but the files remain. Luckily I had backups. Iāll test git soon to see if it fixes this issue otherwise Iād be forced to use a another sync service.
Upon further investigation, I believe the smart merge feature is what caused data loss as it seems the remote graph was what was overwriting my data with empty entries.
How did your test of Git go? I am interested in trying it out.
