Date arithmetic in advanced queries?
Suppose I have a datascript variable ?reference-date that is bound to an OG date such as the integer 20200131. How can I perform date arithmetic so that I can query time ranges relative to that date? For example, I want to do something like this:
    ...omitted: something that binds ?record-date and ?reference-date
    ;; Keep records whose ?record-date is within 60 days (plus or minus) of ?reference-date.
    [(<= (add-duration-to-date ?reference-date "-60d") ?record-date)]
    [(< ?record-date (add-duration-to-date ?reference-date "60d"))]
If I just do something like [(<= (- ?reference-date 60) ?record-date)] then I end up comparing ?record-date to meaningless “dates” like 20200071.
Real date arithmetic is not supported. However, developing workarounds is possible. For example, the following code produces variables ?from-date and ?to-date as integer dates 2 months (i.e. about 60 days) before and after the ?reference-date respectively:
[(str ?reference-date) ?ymd]
[(subs ?ymd 0 4) ?yyyy]
[(subs ?ymd 4 6) ?mm]
[(subs ?ymd 6 8) ?dd]
[(* 1 ?yyyy) ?y]
[(* 1 ?mm) ?m]
[(* 1 ?dd) ?d]
(or-join [?from-y ?from-m ?y ?m ?to-y ?to-m]
  (and
    [(< ?m 3)]
    [(- ?y 1) ?from-y]
    [(- ?y 0) ?to-y]
    [(+ ?m 10) ?from-m]
    [(+ ?m 2) ?to-m]
  (and
    [(> ?m 2)]
    [(< ?m 11)]
    [(- ?y 0) ?from-y]
    [(+ ?y 0) ?to-y]
    [(- ?m 2) ?from-m]
    [(+ ?m 2) ?to-m]
  (and
    [(> ?m 10)]
    [(+ ?y 0) ?from-y]
    [(+ ?y 1) ?to-y]
    [(- ?m 2) ?from-m]
    [(- ?m 10) ?to-m]
[(* ?from-y 10000) ?from-y0000]
[(* ?from-m 100) ?from-m00]
[(+ ?from-y0000 ?from-m00 ?d) ?from-date]
[(* ?to-y 10000) ?to-y0000]
[(* ?to-m 100) ?to-m00]
[(+ ?to-y0000 ?to-m00 ?d) ?to-date]
Thanks, that is very handy. Suppose I wanted exactly 60 days (or some other arbitrary number of days) before and after the reference date, accommodating leap years. Is that possible? Perhaps via a function defined in custom.js?
I had an idea—I think I might be able to define a recursive rule. I’ll try that out and report back if it works.
OK, I think these rules work:
  :rules [
    ;; Leap year every 4 years except every 100 years except every 400 years.
      (feb-days ?y ?febdays)
      [(mod ?y 400) ?mod400]
      [(= ?mod400 0)]
      [(ground 29) ?febdays]
      [(!= ?mod400 0)]
      [(mod ?y 100) ?mod100]
      [(= ?mod100 0)]
      [(ground 28) ?febdays]
      [(!= ?mod400 0)]
      [(!= ?mod100 0)]
      [(mod ?y 4) ?mod4]
      [(= ?mod4 0)]
      [(!= ?mod400 0)]
      [(!= ?mod100 0)]
      [(mod ?y 4) ?mod4]
      [(!= ?mod4 0)]
      (month-days ?y ?m ?mdays)
      [(= ?m 2)]
      (feb-days ?y ?mdays)
      [(ground [[1 31] [3 31] [4 30] [5 31] [6 30]
                [7 31] [8 31] [9 30] [10 31] [11 30] [12 31]]) [[?m ?mdays]]]
      (valid-date-parts ?y ?m ?d)
      [(>= ?y 1000)]
      [(< ?y 10000)]
      [(>= ?m 1)]
      [(<= ?m 12)]
      [(>= ?d 1)]
      [(<= ?d ?mdays)]
      (parse-date ?date ?y ?m ?d)
      [(>= ?date 10000000)]
      [(< ?date 100000000)]
      [(str ?date) ?yyyymmdd]
      [(subs ?yyyymmdd 0 4) ?yyyy]
      [(subs ?yyyymmdd 4 6) ?mm]
      [(subs ?yyyymmdd 6 8) ?dd]
      [(* 1 ?yyyy) ?y]
      [(* 1 ?mm) ?m]
      [(* 1 ?dd) ?d]
    ;; Base case: year, month, and day are all valid.
      (date-fix ?y ?m ?d ?date)
      [(* 10000 ?y) ?yp]
      [(* 100 ?m) ?mp]
      [(+ ?yp ?mp ?d) ?date]
    ;; Day is past the end of the month, but month is OK.
      [(>= ?m 1)]
      [(<= ?m 12)]
      [(>= ?d 1)]
      [(> ?d ?mdays)]
      [(+ ?m 1) ?mp]
      [(- ?d ?mdays) ?dp]
      (date-fix ?y ?mp ?dp ?date)
    ;; Day is before the start of the month, but month is OK.
    ;; Also, month is not January.
      [(>= ?m 2)]
      [(<= ?m 12)]
      [(< ?d 1)]
      [(- ?m 1) ?mp]
      (month-days ?y ?mp ?mpdays)
      [(+ ?d ?mpdays) ?dp]
    ;; Also, month is January.
      [(= ?m 1)]
      [(< ?d 1)]
      [(- ?y 1) ?yp]
      [(ground 12) ?mp]
      (month-days ?yp ?mp ?mpdays)
      (date-fix ?yp ?mp ?dp ?date)
    ;; Month is after December.
      [(> ?m 12)]
      [(+ ?y 1) ?yp]
      [(- ?m 12) ?mp]
      (date-fix ?yp ?mp ?d ?date)
    ;; Month is before January.
      [(< ?m 1)]
      [(- ?y 1) ?yp]
      [(+ ?m 12) ?mp]
      (date-add ?indate ?years ?months ?days ?outdate)
      (parse-date ?indate ?y ?m ?d)
      [(+ ?y ?years) ?yp]
      [(+ ?m ?months) ?mp]
      [(+ ?d ?days) ?dp]
      (date-fix ?yp ?mp ?dp ?outdate)
Examples:
      (date-add ?refdate 1 0 0 ?oneyearlater)
      (date-add ?refdate 0 6 0 ?sixmonthslater)
      (date-add ?refdate 0 -6 0 ?sixmonthsearlier)
      (date-add ?refdate 0 0 180 ?hundredeightydayslater)
However, it seems to be quite slow. Anyone have any ideas to improve performance?
If you are open to use custom.js, the best solution would be to implement a kit.
It isn’t slow at all when I try your examples. There has to be something else going on with the rest of your actual query.
