The date format dd.MM.yyyy is gone from the settings in 0.9.1, on i(Pad)OS and macOS. Why?
(On the Mac) I cannot even set this in the config file. It just gets changed back. I could swear it used to be in the menu. And it should—it’s a common date formate in larger parts of Europe.
Also I could live with EEEE, dd.MM.yyyy, too, if only Logseq would respect the language settings and not show the EEEE part always in English.
Update: At least with 0.9.3 on the Mac I seem to have managed to change the date format as desired via config.edn.
Support for dd.MM.yyyy was dropped. detailed here: fix: some date related issues by cnrpman · Pull Request #7059 · logseq/logseq · GitHub
Huh. Thanks for the link.
That’s … quite something to drop.
If Logseq only didn’t show the weekdays in similar, longer date formats always in English instead of the language selected in settings.
Bummer. Not a small one. ![]()
Argh. 11 months old … Translate Dates · Issue #5421 · logseq/logseq · GitHub
yeah, they said “temporarily” dropped, but it’s not much to pin hope on. there’s so much on their plate. x_x
As this is not a bug but a “temporary” lack of feature or a “known issue”, I’m closing this thread ![]()
If you want to ask for this feature, feel free to start a new post in the Feature Requests - Logseq section.
