Erik
#1
When a block starts with
- text…
Then Logseq automatically inserts a new line with a “2.” after pressing Enter.
That way the whole numeration will be in one bullet/block, at least that’s how Logseq wants it.
I want to have all numbers in single bullet points. Thus, the automatic behavior to keep everything under one bullet is unwanted.
Is there a way to deactivate it?
Ed_Nico
#2
Hi,
This is caused by Do What I Mean (DWIM). To disable it, add the following to your config.edn file:
:dwim/settings
:admonition&src? false
:markup? false
:block-ref? true
:page-ref? true
:properties? false
:list? false
Insert it before the last } and play around with true / false to suit your need
Erik
#3
Amazing! Thank you! It worked.
