Hi, after running a re-index Logseq started (again) to show me file conflicts (encrypted Vs. decrypted). That is the x-time I run into encryption issues, so I decided to disable the feature and to use the logseq-encrypt-ui tool to decrypt my entire graph. However, even the decryption process was successful, I ended up with a lot of empty md files and the original files are renamed to .bak still containing the encrypted blocks. Is there a way to decrypt the blocks or md files individuallly?
See example here:
-----BEGIN AGE ENCRYPTED FILE-----
YWdlLWVuY3J5cHRpb24ub3JnL3YxCi0+IFgyNTUxOSBYdmtZK2xwb2dWdi9pNWpn
VVZZZm8zalcyMFVrczh3d1ozSlo0Q2xOQWxJCjljc2J5QmgrTzdKbmc3cGlrdDJF
S001SGxjVDQ3L0VDdkV4TmttbmZtTlEKLT4gcC1ncmVhc2UgXVFxIFxHL1E4JXQg
dyoKTGR2eTBWTi92aURYZXJvc0JsekpiRk1VRS9FU3J1NjkvT01xMVlJcWtwRlZJ
a1FheklzTjBoNHhudkNhamgyOQpzMWVTQWNucVhSZmpTMmxZUS9uYUEvTjQ2cldT
ZnFUZXRXbHFvb1lJM1dZVmJOMkZ2VW9tL3hjdG9iQy9ONWdqClpUOAotLS0gcGNO
UzRkOWNLUnNjeTA3b3FuYnB5c2luMFJsRG1zeEM3Z2o3UDh2bEtpZwobzgg6/F3a
Xj/GXbpIX2+vfeMKpEw6768sdE6N48R3CA==
-----END AGE ENCRYPTED FILE-----
Cheers
Andre
