Since logseq supports the possibility to add a language to the codeblock for syntax highlighting, I would suggest that somehow it would be possible to set a kind of default language for every new codeblock.
In my case I always have to add “kotlin” for my codeblocks, because in 99.999% of all cases I only write kotlin code into logseq for the moment.
Possible workaround is maybe to create a template, but I’m not sure if this would be faster…
(is there a possibility to add a template via shortcut?)
Yes, you can use a template too. But you will have to do it in two steps (type /template, then type the template name). Using is command is one step, therefore quicker.
