For context this is the existing feature I am referring too:
Logseq gives us the ability to change the default behavior which controls how many blocks are expanded in the reference panel when opening a page, but in some cases I have found a need to change this behavior for only a select number of pages.
I would like to propose a feature request to add a page level setting that would control how many blocks are expanded when opening a page. This can be a page-property key that’s defined in the page like so:
filters:: {}
open-blocks-level:: 4
Let’s say you have a default-open-blocks-level setting of “2”. When opening this page, Logseq would read the property key open-blocks-level and value of 4 and expand up to 4 levels deep instead of the default 2. Any other page that does not contain this property-key would result in using the default value of 2.
