Hi,
Is it possible to make the dependencies task in Logseq?
For example, Task B will be started after Task A completed.
Once todo Task A checked, Task B will be started from the date when Task A completed + Duration required for Task B.
Any ideas?
Hi,
Any ideas?
Perhaps those project management features could be implemented as plugins someday.
Another simpler feature I’m missing: showing totals of task durations & estimates on parent tasks.
Or actually any kind of calculation (Excel like) on children blocks.
I’d also love to see task dependencies implemented
This would be awesome and probably pretty easy to get a basic version out
