I found this old feature request and was wondering if this is possible right now?
Using the new Logseq db, I managed to do it in List View, but it doesn’t look like it works in Database View.
With Logseq DB, when you are in table view, you can click on the node’s text/row, and it will go into edit mode. After editing, hit ENTER.
Weird, it’s not working for me.
I’m testing on https://test.logseq.com/ - should I be using a different link?
See below. I created a node with the content “A book”, tagged it as #book, went into that tag’s page, edited the node content within the table (I appended the word “edited”, as shown in the image) - but as soon as I hit ENTER, the edit is reverted and nothing happens.
Here is how it is working for me on the Edge browser.
I’m on Chrome.
Are you using the same link I am? test…
Edit: it seems I was using the wrong link.
It works here (including on Chrome):
Turns out it doesn’t work whenever the node being edited is also open in the sidebar.
Is this expected behaviour?
The inverse works (editing the node in the sidebar changes the content in the tag table).
