Suppose I’m in a multi-paragraph block. If part of the block is at the top of my screen, and I use arrow keys to move the cursor up from there, I find that the text doesn’t scroll to keep up with the cursor. The cursor disappears. I have to use the mouse to scroll to find it.
The same is true if the cursor is at the bottom and I use the down arrow key.
How do I make the text scroll with the cursor, or is this a bug?
