I’ve been researching various graphy brain-like systems for a while now, but I’m not clear whether logseq has any labeling or knowledge storage capacity for an edge, a link between two nodes. With traditional RDF you have a subject-predicate-object graph philosophy where, e.g., Tom is a captain where Tom is one vertex (with an ontology tag/URI associated with it), is a is the predicate, the edge connection (also with an ontology tag/URI) and captain is the object, i.e., the second vertex connected by is a to vertex Tom. Does logseq have any sort of edge capabilities? My cursory investigation hasn’t revealed anything.
Another example where edge knowledge is very crucial would be to imagine a city street grid as a set of vertices of cross streets and the streets themselves as the edges between the cross streets. For example, 42nd/5th would be a vertex, and 42nd and 5th would be edges. Then you’d have to have a meta-graph to express all of 42nd and 5th. So in such a situation the edges are just as important as the vertices. Is there in fact any sort of edge “labelling” or knowledge building?
