Fairly straightforward. I would like to be able to hit a hotkey and navigate to today’s daily, since I find myself going there frequently.
Bonus would be hotkeys for going to next/previous day as well, but that’s probably a separate request.
On Mac OS cmd+j does that for me. On Windows and Linux I’m guessing ctrl+j would do the same. Also clicking the Logseq icon on top left brings the daily view.
You are correct, thank you! In that case, I would like to change this request to “document Cmd-j somewhere”
(For the record, I knew about the clicking of the icon, I was specifically concerned with a keyboard interaction.)
The only place I’ve managed to find all the hotkeys is here in this config file - not nicely readable though!
In last few Logseq releases (current 0.2.5) the Help/?
button will show you Keyboard Shortcuts
next to Customize
button that will show you all shortcuts and ability to customize all of those keyboard shortcut.
In the latest version (0.7.8) there are bunch of navigation shortcuts:
Since the last few releases and the up implementing “lazy load” technology, opening the Journals page should no longer have a delay.
If you embed many videos and notice a degraded performance, make it a practice to collapse the branches that have videos. We have no control over how fast videos are loaded; this depends on the video’s host.
P.S. Tagging team members generally doesn’t help to get features bumped, especially not a non-coder like me Maybe if one of the engineers has some time to quickly code this, but then there are dozens of other things that have a higher priority. Opening this feature request and gathering votes is the way to go to get it noticed.
You can always try the go home plugin.
Noted, I took it as a rule to collapse any queries and embedded things in Journal view. Thanks!
Thank you for your feedback, I just wanted to help and thought you are doing product management, just assumed 533 views was a hint to add this minor thing. I will open a feature request for and one and also for any future ideas that I will get
it looks like go home still land me on main journal page. It that the plugin you are talking about: GitHub - sawhney17/logseq-go-now ?
I’m “only” community manager. While I do forward feedback that I see in the community, I’m by no means a product manager. Also, the team generally decides based on number of votes (not views) what feature requests to work on.
