Eisenhower Matrix With Default Queries
I’m starting to play around with the Eisenhower Matrix theory for productivity and limiting procrastination. Since everything I do from TODOs to notes is inside Logseq I wanted a native way to achieve this.
I did see the plugin that was made to have a proper Eisenhower Matrix placed within Logseq but for me that was a bit too much for my flow. So, I set up a system to use the default-queries section of the config.edn file to achieve a more native approach.
First a bit of code then I’ll explain it for anyone that is not farmiliar with advanced queries in Logseq:
 :title [:b "Do Now"]
         [?block :block/marker ?marker]
         [(contains? #{"NOW" "DOING" "TODO"} ?marker)]
         [?block :block/content ?blockcontent]
         [?block :block/page ?page]
         [?page :block/name ?pagename]
         (page-ref ?block "urgent")
         (page-ref ?block "important")
  :collapsed? false
  :breadcrumb-show? false
  :table-view? false
The above code is to represent the Do Now block in the Eisenhower Matrix. Any TODO, NOW, or DOING that has tags #urgent and #important will automatically show up in this section (which I have at the top of my default queries list).
Example:
For the next two all that changes from the code above are the two (page-ref ?block ...) lines.
So for tasks that fall under the schedule section of the Eisenhower Matrix the tags would be something like #not-urgent and #important. And for the Delegate section I’m using #urgent and #not-important.
The final section of the Eisenhower Matrix is the Don't Do section and would be given the tags #not-urgent and #not-important. Though I’m leaving this out of my default-queries because they are useless tasks that distract from the important ones anyway.
Here’s an example of the end result in on the journal page of Logseq:
Hope this helps those of you looking for a more native way to implement this useful productivity framework.
Let me know if you have questions. :wave:
I use priority A for important/urgent, B for important/not urgent and C for not important/urgent since they’re easy to update on the fly as needed. Do you use priority A, B, and C to compliment your Eisenhower tagging or in lieu of?
This is fabulous approach and I may switch to having the default-queries use priority to place the into buckets. As I agree with you that they are very easy to update quickly. They will also allow me to type less to achieve the same result.
I have not used them with the approach I explained in my original post. Before I started to use the Eisenhower Matrix I would use priority to rank my tasks. But this fell short for me since I don’t think I should have multiple of the same priority.
Here’s and updated advanced query to use :block/priority instead of custom tags:
         [?block :block/priority "A"]
  :collapsed? false
  :table-view? false
One little remark. You don’t need these three lines in your query.
They don’t do anything :wink:
Thanks for the heads up :sweat_smile::pray:t2:
Thanks @jrswab, this got me going. I created a slightly altered Eisenhower Matrix with this:
:default-queries
{:journals
     :title [:b "🅰️ DO - Important & Urgent"]
             [(contains? #{"TODO" "DOING" "NOW"} ?marker)]
     :result-transform (fn [results]
       (let [priority {"DOING" 1 "NOW" 2 "TODO" 3}]
         (sort-by (fn [h]
                    (get priority (:block/marker h))) results)))
      :collapsed? false
      :table-view? false
     :title [:b "🅱️ SCHEDULE - Important"]
             [?block :block/priority "B"]
         (sort-by (fn [h]
      :collapsed? false
      :table-view? false
     :title [:b "❌ ELIMINATE - Not Important"]
             [?block :block/priority "C"]
         (sort-by (fn [h]
      :collapsed? false
      :table-view? false
     :title [:b "❓ UNPRIORITIZED"]
             (not [?block :block/priority])
         (sort-by (fn [h]
      :collapsed? true
      :table-view? false
Mine uses A, B, C priority for Important/Urgent, Important/Not Urgent, and Not Important respectively. Any tasks not prioritized is grouped as well.
I don’t put any time limits as I want to clean up old tasks anyway.
