Anyone have a way to exclude tags from search? I am only looking to get results for pages and blocks as they are more specific and by getting tags is it really cluttered. I know pages and tags are both the same asset but would love to separate for search Thanks
I have tags and pages both using the term mindset. The pages are most specific and the tags are both single words #mindset and nested mindset/daily practice or mindset/shadow work. I am trying to avoid having both come up during search. If I want to search tags I can use the tags plugin so don’t need tags to populate general search for pages. Thank you
If you have general search needs, try the plugin Smart Search, it has a much simpler syntax for searching. Excluding a tag for example, can be achieved via #!mytag syntax. More info:
