I use the logseq-calendars-plugin to import my Google calendar to Logseq. It seems that all recurring events fail to be imported into logseq, but the other individual non-recurring events are fine. Any solution to this problem? Thanks!
The best place to report bugs/issues with plugins is often its GitHub page.
I checked the plugin’s issues repo and found this issue, which sounds like yours:
The solution seems to be here:
I hope this helps!
Indeed, following the solution above, the issue is now fixed. Thank you so much for the help!
Thank you very much ! It solved the problem for recurring events…I’ve set the date for 2055 …Maybe it can be reported to who have made the plugin as a bug to fix ?
