File explorer from within Logseq
Table of Contents
  • Introduction
  • Screenshot
  • Current Features
  • Code
Introduction
This is:
  • a safe subset of File management from within Logseq, proof-of-concept
    • it doesn’t depend on it
    • the unsecure now builds on top of the safe
  • to either:
    • use as it is for:
      • exploring folder hierarchies
      • opening files or folders in external applications
    • build custom functionality on top of it
      • this is the real feature, not to replace other explorers
Screenshot
Current Features
  • Use a simple macro to turn any block into a node about your file system, e.g.:
    • {{foldername C:/pathto/parentfolder}}
    • Such blocks can be safely:
      • deleted:
        • no changes to the file system
      • moved:
        • position is irrelevant
      • copied:
        • each copy is independent
  • Hover to show the available buttons.
    • Here only one and only for folders, but custom buttons are supported.
  • Simple click on the name of an entry to ask the operating system to open that folder or file.
  • Simple click on button Read to see if that path currently exists in the file system.
  • Alt + click on button Read to auto-generate blocks in a hierarchy that matches the one currently on the drive.
    • This may take some time for big trees.
      • Try first with a small one.
    • Repeat to refresh:
      • The blocks are not synced with the file system.
      • Any outdated blocks get deleted.
        • Copies don’t get affected.
          • Can use this feature for comparisons.
  • Expand a folder-block to show its contents.
    • Nested blocks don’t get affected by expanding/collapsing.
      • They maintain their values since the last Read of any of their ancestor blocks.
  • Zoom on a block to focus as usually.
Code
  • At the end of file preload.js, normally inside ...\Logseq\app-0.9.18\resources\app\js:
    contextBridge.exposeInMainWorld('getfs', ()=>({
      access: fs.access,
      readdir: fs.readdir,
      readdirSync: fs.readdirSync
    • This needs to be re-added after every update of Logseq.
  • Inside file config.edn, inside macros{}:
    :filename "<div class='kit filesystem' data-kit='filesystem' data-type='file' data-name='$1'></div>"
    :foldername "<div class='kit filesystem' data-kit='filesystem' data-type='folder' data-name='$1'></div>"
  • Inside file custom.css:
    button.filesystem {
      font-size: 12px;
      line-height: 14px;
      margin: 0px 8px 0px 8px;
      padding: 2px 4px 2px 4px;
    button.filesystem.read {
      background: #ff9900;
    div.block-content button.filesystem {
        visibility: hidden;
    div.block-content:hover button.filesystem {
        visibility: visible;
    a.external-link.file-link {
        border-bottom-style: none;
  • The code below requires having kits inside file custom.js .
  • Inside page FileSystem in Logseq, put the following code in a javascript code-block:
const LS = logseq.api
const Module = logseq.Module
const Kits = Module.Kits
function statusMsg(status, msg){
    Module.Msg.ofStatus(msg, status)
const error = statusMsg.bind(null, "error")
const info = statusMsg.bind(null, "info")
const success = statusMsg.bind(null, "success")
const fs = window.getfs && getfs()
if (!fs) return error("missing fs")
const Block = (Module.Block || Module.setChild("Block"))
.setStatic(function forEachChild(block, cb){
    block.children.find( (arr)=>{
        const child = LS.get_block(arr[1])
        if (child) return cb(child)
.setStatic(function parentOf(block){
    return LS.get_block(block.parent.id)
const FS = Module.setChild("FileSystem")
.setStatic(function appendButtonsForBlock(div, block){
    const blockId = block.uuid
    if (block.properties.foldername) div.append(
        FS.button("Read", FS.onReadClicked, blockId)
.setStatic(function button(name, handler, arg){
    const btn = Kits.createElementOfClass("button", "filesystem", name)
    btn.classList.add(name.toLowerCase().replaceAll(" ", "-"))
    Kits.addClickEventToButton(handler.bind(null, arg), btn)
    return btn
.setStatic(function deleteMissingBlockChildren(block, cb){
    const rest = []
    var rem = 0
    Block.forEachChild(block, (child)=>{
        rem += 1
        fs.access(FS.fullPathOfBlock(child), (err)=>{
            if (err) {
                LS.remove_block(child.uuid)
                console.log("DELETED BLOCK: " + FS.nameOfBlock(child))
            } else {
                rest.push(child)
            if (!--rem) cb(rest)
    if (!rem) cb(rest)
.setStatic(function fullPathOfBlock(block){
    const name = FS.nameOfBlock(block)
    return (!name) ? "" : FS.pathOfBlock(Block.parentOf(block)) + name
.setStatic(function iconForBlock(block){
    const props = block.properties
    return (props.foldername) ? "&#xeaad" : FS.iconForFilename(props.filename)
.setStatic(function iconForFilename(filename){
    return "&#xeaa2"
.setStatic(function insertChildBlock(parentBlock, path, name){
    const property = FS.isFolder(path + "/" + name) ? "foldername" : "filename"
    const nameblock = {properties: {[property]: name}}
    var found
    Block.forEachChild(parentBlock, (sibling)=>{
        if (FS.nameCompare(sibling, nameblock) > -1) return found = sibling
    if (found && !FS.nameCompare(found, nameblock)) return found.uuid
    const customUUID = LS.new_block_uuid()
    const properties = {[property]: name}
    const options = {customUUID, properties}
    if (found) {
        options.before = true
        options.sibling = true
    const content = "{{" + property + " " + name + "}}"
    const uuid = (found || parentBlock).uuid
    LS.insert_block(uuid, content, options)
.setStatic(function isFolder(path){
    try { fs.readdirSync(path) }
    catch { return false }
    return true
.setStatic(function nameCompare(a, b){
    const aprops = a.properties
    const bprops = b.properties
    const aname = aprops.filename
    const bname = bprops.filename
    if (aname && !bname) return 1
    if (!aname && bname) return -1
    const prop = (aname) ? "filename" : "foldername"
    return aprops[prop].toLowerCase().localeCompare(bprops[prop].toLowerCase())
.setStatic(function nameOfBlock(block){
    const properties = block.properties
    return properties.foldername || properties.filename
.setStatic(function nameOfErr(err){
	return err.message.slice(0, err.message.indexOf(":"))
.setStatic(function onReadClicked(blockId, e){
    const block = LS.get_block(blockId)
    fs.access(FS.fullPathOfBlock(block), (err)=>{
        if (err) return info("doesn't exist")
        if (e.altKey) FS.updateTreeBlock(block)
        else info("Alt to read")
.setStatic(function onTreeBlockUpdated(spanIcon, iconHtml, res){
    spanIcon.innerHTML = iconHtml
    if (res === "done") success("done")
    else error(res)
.setStatic(function pathOfBlock(block){
    const foldername = block && block.properties.foldername
    return (!foldername) ? "" : pathOfBlock(Block.parentOf(block)) + foldername + "/"
.setStatic(function sortBlocks(blocks){
    blocks.sort(FS.nameCompare)
    var previous
    const options = {sibling: true}
    blocks.forEach( (block)=>{
        if (previous) {
            LS.move_block(block.uuid, previous.uuid, options)
        previous = block
.setStatic(function updateChildren(parentBlock, cb){
    var rem = 0
    Block.forEachChild(parentBlock, (child)=>{
        if (!child.properties.foldername) return;
        rem += 1
        FS.updateFolderBlock(child, ()=>{ if (!--rem) cb("done") } )
    if (!rem) cb("done")
.setStatic(function updateDiv(div, blockId){
    const divParent = div.closest(".block-content")
    divParent.querySelector(".block-content-inner").remove()
    const divProps = divParent.querySelector(".block-properties div")
    const spanIcon = Kits.createElementOfClass("span", "ti")
    spanIcon.innerHTML = FS.iconForBlock(block)
    const link = Kits.createElementOfClass("a", "external-link", FS.nameOfBlock(block))
    link.href = "file:///" + FS.fullPathOfBlock(block)
    link.target = '_blank'
    link.classList.add("file-link")
    divProps.firstChild.remove()
    divProps.prepend(spanIcon, " ", link)
    FS.appendButtonsForBlock(divProps, block)
.setStatic(function updateFolderBlock(block, cb){
    const path = FS.fullPathOfBlock(block)
    const uuidParent = block.uuid
    fs.readdir(path, (err, names)=>{
        if (err) return cb(FS.nameOfErr(err) + ": " + path)
        FS.deleteMissingBlockChildren(block, (rest)=>{
            if (!names.length) return cb("done");
            if (rest.length) FS.sortBlocks(rest)
            names.forEach( (name)=>{
                FS.insertChildBlock(block, path, name)
                block = LS.get_block(uuidParent)
            if (!rest.length) LS.set_block_collapsed(uuidParent, true)
            FS.updateChildren(block, cb)
.setStatic(function updateTreeBlock(block){
    const selector = "div.ls-block [blockid='" + block.uuid + "'] .ti"
    const spanIcon = document.querySelector(selector)
    const cb = FS.onTreeBlockUpdated.bind(null, spanIcon, spanIcon.innerHTML)
    spanIcon.innerHTML = "&#xeaae"
    FS.updateFolderBlock(block, cb)
logseq.kits.setStatic(function filesystem(div){
    const type = div.dataset.type
    const name = div.dataset.name
    const blockId = div.closest(".ls-block").getAttribute("blockid")
    LS.upsert_block_property(blockId, type + "name", name)
    setTimeout(FS.updateDiv, 0, div, blockId) // wait UI
FS.fs = fs
preload.js doesn’t exist in my logseq folder. Am I to use custom.js instead?
  • The file preload.js is part of the application data. Its default location will change depending on your OS.
    • If you use Microsoft Windows, it is likely under C:\Users\{username}\AppData\Local\Logseq\app-0.10.12\resources\app\js
Excellent! As always, I’m amazed by what you manage to do with kits, and I’m very appreciative that you shared it.
The read is a bit slow when there are many nested directories to traverse and during this time logseq is unresponsoive, but afterwards it’s perfect.
