Previously I used to type “/” to open the commands list and then start typing the first letter of the command and it would go to the show the nearest matching command in the list.
Currently this doesn’t work and I have to type the whole command e.g /template to filter to show the Template command and sometime this doesn’t work either and I have to scroll down to the list.
Desktop version works properly.
Is there anyone else facing this?
I am using logseq 0.10.6 in android 12.
