Here’s your query.
Important notes :block/name is the lower-case name of a page. When you use namespaces, it will get everything referencing the namespace regardless of what level of the namespace.
So project gets Project, but also Project/Personal.
project/personal will get Project/Personal and also Project/Personal/test, but not Project.
See the screenshot I added
Thank you so much — this is super helpful! I guess I need to start learning advanced queries much better to beef up my workflow.
One thing I forgot to mention in my original workflow - sometimes I tag the task directly rather than nesting under a tag (see last meeting example in this screenshot). Any chance you can help me modify the original query to get these tasks as well? (Your query currently returns the tasks from the first two meetings, but does not return tasks from the third meeting in this screenshot)
Hi there, i am new to advanced queries in Logseq.
I found your hint for queries in namespaces and tried to apply it to my own example, but get no results.
This is my example. I try to get a query that shows the two tasks in the sub-pages of the namespace.
This goes from relatively simple to relatively complex pretty fast.
First of :block/refs doesn’t get what you need.
Also you want the block on the page and not the parent of the block, though in this case that is the same, but if your task is under a parent block you won’t retrieve it.
Next getting a namespace is only 1 level deep, and here’s where the complexity comes from.
I’m going to assume you don’t want that to be static
So I use rules to create a recursive search to find all pages under project, no matter their dept.
Here’s the query I created:
Perfect! It works!
Now I really can draw the Power of Logseq for my purposes.
Thanks, mighty wizard.
I do not understand the magic yet, but can use it and am eager to learn more.
When i put “project” (or the final target string) in lowercase letters, it works as intentioned.
Next i’ll try to filter on tasks with priority “A”.
Maybe i can do it without help from a magician.
Dear Siferiax, I do not want to be greedy but could you extend your helpful Query so that it Filters Namespace + Tasks + Priority “A”
As a beginner i still struggle a little with learning datalog.
Yes. :block/name is always lowercase. I forgot to mention, I generally add that for clarity!
Pages have 2 names, one is lowercase and stored in the attribute :block/name and the other is their original name case stored in :block/original-name.
I generally use :block/name so we don’t have to think how exactly we wrote the name of a page
For filtering priority we have the attribute :block/priority
So we will need to add the line: [?b :block/priority "A"] to the query.
Alternatively we can do this the same way as we did for the task itself.
Hi there @Siferiax , many thanks for the solution… its nearly perfect.
If you allow one last question:
Sometimes i would also note some tasks in the root layer of a namespace (“project/…”).
Is it possible to include these tasks with priority into the query results?
Someone should develop a GPT based AI that can transform natural language queries into advanced logseq queries! I wonder if anyone is thinking about this?
Hi there,
i already found the great Query-Builder-Tool from adxsoft
but couldn’t figure out how to build a recursive query for the namespaces like the one @Siferiax provided. Maybe its just a matter of time learning the nuances of datalog.
For now the hints from Siferiax provides a very powerful solution for project management in Logseq.
But now I’m trying the following as the inverse - i.e. find all todos that don’t have any project tags, but it’s finding no results (despite the fact that I’ve created some test todos without project tags). Any idea how I can fix this? Thanks very much in advance!
