When I search for something in the journal entries and then open it, it is shown on a separate page. Ideally, I’d like to locate the result in the entire journal (i.e. just scroll to it without opening another page), but I can’t find a way to do it. Usually, you can navigate from a block to its parent, but since the journal is not technically a parent of a day’s page, that does not work.
The next best thing I found is the commands to navigate to the next or previous journal entries.
