Thank you both for responses. Yes, Esc + Del works. I had not discovered that yet. Isn’t documented. Yes, the Delete Block option should be in the block context menu just after Cut.
Actually it’s two shortcut. Escape exits out the n b block and selects it. Delete just deletes it. You can also shift click or command click to select multiple and then click dlete to delete it
