So the first step to understand is the structure of the data. And in that structure what is actually returned.
Say we have this data.
TODO a task [[@home]]
This is multiple rows in the database.
Each row in the database looks like this:
[id attribute value]
In this case id will always point to the id for that block in the database. The attribute will be the different types of information stored about the block and the value the value this attribute has.
You can right click on a bullet in developer mode to show this.
For the above:
{:block/uuid #uuid "64c8e59b-d173-4524-a1a7-adc76a9667cc",
:block/properties {},
:block/journal? true,
:block/left {:db/id 1592},
:block/refs [{:db/id 4} {:db/id 1597}],
:block/journal-day 20230801,
:block/format :markdown,
:block/content "TODO a task [[@home]]",
:db/id 1594,
:block/path-refs [{:db/id 4} {:db/id 1592} {:db/id 1597}],
:block/parent {:db/id 1592},
:block/unordered true,
:block/page {:db/id 1592},
:block/marker "TODO"}
The first part is the attribute and the second the value.
You can see the attribute :db/id has a value of 1594.
So I can write this (silly) query:
{:title "Give me my block"
:query [:find ?b
[1594 :block/content ?b]
And that works:
So now when we look at refs, I’m sure you’ll see what the value is here.
References to other id’s in the database.
This will not work for our sorting purposes, we need the actual data, not the id’s.
There are 2 references, because TODO is actually a page that is referenced here.
This is another reason we can’t sort on :block/refs, because it returns multiple values.
Also your query syntax isn’t quite correct, but that is another issue.
Without sorting:
With sorting:
The query:
{:title "List of DOING tasks sorted by linked pages"
:query [:find ?area (pull ?b [*])
:keys area task
[?b :block/marker ?m]
[(= ?m "DOING")]
[?b :block/page ?page]
[?b :block/refs ?a]
[?a :block/original-name ?area]
[(!= ?area ?m)]
(sort-by (fn [s] (get-in s [:block/properties :area])) < (map (fn [m]
(update (:task m) :block/properties
(fn [u] (assoc u :area (get-in m [:area]))
) result))
:breadcrumb-show? false
:group-by-page? false
Yes there is some trickery here to make it work.
Also no you don’t need the view. If you want a table, press the table button:
And press the settings icon to change which columns are shown:
Let me know if you need more help with this!
