Help! How Do I change the graph view page size?
Hello, I have a question regarding the graph view page. My page only shows up as half a page, but I want it to be a full-page view. How do I change that, if possible? Any help for this novice would be so appreciated. I appreciate any help you can provide.
Kane
Well, you can click on Nodes and then just activate everything.
If this did not work, then you can try to re-index your Graph.
Thank you, but neither worked. I do realise now that if I switch the theme to another then the graph view page is full size. So I am guessing that it is either down to the theme itself or something a plugin perhaps is conflicting with the theme
